Home
Forums
General SVO Discussion
2000 VW won't restart shortly after being turned off while on Veggie, Please Help!!|
Sounds like air in your veggie lines to me.
1984 Mercedes 300SD 1994 Chev 6.5 Suburban |
I have some more information. After making my previous post, I was looking around under the hood of my car, and found that the spin on filter for the SVO was leaking a bit because it was not tight on its base. It is inside of a heater hose wrap and I haven’t done anything to it since I converted the car, so I guess it must have vibrated loose over time. I guess that would mean that you were quite right Graplr, thanks very much. Incidentally, about how often should the spin on filter be replaced?
2000 VW Jetta TDI, Homebuilt SVO conversion. |
Hi Joe
I have an 03 TDI and I replace my filter 2 times a year just because. They are cheap and preventative maintenance is better that troubleshooting on the side of the road. My friend had the same situation where the filter company made a slight change in the filter design and he sucked a little air at the filter head.
Merk 03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves |
You should consider adding a vacuum gauge to your system to help trouble shoot issues like this. It will tell you when your filters are starting to clog, if your switching valve is working, i fyou have air in your fuel lines, and provide other useful info.
98 Jetta TDI with aluminim tank HotFox fuel pickup, HOH, FPHE, Coolant Heated VW Oil Cooler Filter,VegTherm, Injector Line Heaters, 6 port Pollak, and 3 port Pollak for Backflushing veg. filter 60,000 grease miles B100 - B20 Main Tank Fuel depending on outdoor temps. 83 Benz 240D 3 Gallon purge fuel tank, Heated Pickup Stock Tank, 12V pump, HOH, Coolant Heated Filter, 16 Plate FPHE, Injector Line Heaters, 2 Greasecar Valves, Looped on Veg., Return to tank diesel.and Injector overflow return to veg. tank |
Home
Forums
