Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    2,5 Micron Filters???
I have called and can not find 2 or 5 micron filters and filterheads to mount them. I am using a remote location so I need the filterhead. Where can I find them??
95 Safari RV 33'
Cummins 5.9L (230HP) B Series
Wix 24770 1-14 filter head ~$21.00
WIX 33674 2 micron or CAT 1R0749 filter $10.00
2001 Ford Excursion 7.3l PSD
1984 Ford F-250 6.9l IDI
Over 18,000 miles on WVO.
DN
This is a copy/paste off the John M. Ellsworth web site. I like cast iron filter heads.Good selection of filters.
The head is also available from Tractor Supply Company, but is about $25 (pricy).
ORDER ONLINE or Toll Free 1-800-333-3331
Cim-Tek 3/4" NPT Fuel Filter Adapter
Used on: 200E, 250E, 260, & 300 series.
Item #
CIM200H-50003
Manufacturer
Cim-Tek
Shipping Weight
3 lbs.
Usually Ships
Within 24 hours
Pipe In/Out
3/4" NPT
Material
Cast Iron
Nose Outside Thread
1"-12 UNF
Petro Clear#
75N112
Our Price:
$11.62
Volume Pricing
$10.92 2-5
$10.49 6 or more
Additional Cim-Tek Fuel Filter Adapter Series 200, 400, & 800 Series
SKU Pipe In/Out Material Nose Outside Thread Petro Clear# Price Qty
CIM810-50163 1 1/2" NPT Aluminum 1 1/2"-16 UNF 1.50N1.5-16 $33.28
CIM200H1-50002 1" NPT Cast Iron 1"-12 UNF 100N112 $11.67
CIM200AH-50004 1" NPT Cast Iron 1 3/8"-12 UNF 100N13812 $12.26
CIM50032 1" NPT Aluminum 1 1/2"-16 UNF --- $22.16
CIM805-50109 1" NPT Aluminum 1 1/2"-16 UNF 1.00N1.5-16 $27.92
CIM50032N 1" Nickel-Plated 1 1/2"-16 UNF --- $26.72
CIM820-50011 2" NPT Aluminum (Two Filters) 1 1/2"-16 UNF D2.0N1.5-16 $132.41
CIM200H-50003 3/4" NPT Cast Iron 1"-12 UNF 75N112 $11.62
CIM200HA-50181 3/4" NPT Aluminum 1"-12 UNF 75N112A $14.13
Cim-Tek 200 Series Fuel Filter
JME Part#: CIM200E10-70002
As low as $5.97
ALL PRODUCT DEPARTMENTS
E85 / Biodiesel
Filters
Fuel Oil Delivery
Marina Fueling Equipment
Material & Drum Handling Equipment
Service Station Equipment
Sorbents & Wipes
ORDER ONLINE or Toll Free 1-800-563-8858
© 2009 John M. Ellsworth Co., Inc.
David Norwood
Updated 1/2009 .
CIM200H-50003
is 10 microns...
DN
The post above is just a glance at the site with emphasis aimed at the filter head.
The site has 2 to 30 micron filters available. Easy site to work with.
David Norwood
Updated 1/2009 .
I have used both Cim-Tek and WIX . Good prices on WIX at www.filter1.com and www.fleetfilter.com (WIX with NAPA label) .
more info -
http://www.frybrid.com/forum/s...25&highlight=filter1
http://www.rocketcityrockcrawl...l/PPF_2008-02-25.pdf
1994 F250 IDI 7.3 NA E4OD
more info -
I use that base and the 2 micron 10"+ WIX filter on it for both diesel and wvo - they seem to last forever - there is also a 7" size for tighter spaces. Filter1 is definitely the most price competitive vendor.
I found Fleetguard carries them. But my FS1000 10 micron filter seems to clog after 100 gallons. I have heat and the oil is centrifuged. Has anyone had this problem??
95 Safari RV 33'
I heat settle, cf then polish with a 1 micron (nominal) - my 2 micron filters are good for about 5-6k...
Sorry this is late, but I'm a fan of Hydac filters:
http://www.hydacusa.com/litera.../filters/spin-on.pdf
I've been using the MF80 model for my settling/filtering system and no problems. I've had one of Dana Linscott's "Goldenglow" filter set ups, but it leaks (not sure why, but I have some ideas: too many fittings, and Goledenrod filters are only rated to 150 deg).
I've got another MF80 head on order to replace my VO filter in my truck. It's rated to 250 deg, had 1/8" NPT ports for gagues which should be perfect for a glow plug or two.
I'm going to have to reconfigure my thermostat though, not sure how I'm going to do that, the nice feature of the goldenglow design is the rectangular filter head fits nice with a water heater thermostat, and if wired correctly, the system will not switch to VO until hot enough, preventing premature switchover.
Hope this helps someone.
'93 Dodge 250 - 5.9L cummins, 275K w/40K VO miles so far. Cold-upflow settling with gravity feed through 10 and 3 micron spin-on filters (which have not needed changing for 500+ gal and counting. Hooray for cold-upflow settling! Thanks john galt! )
Location: Eatonville, WA | Registered: 30 September 2007Reply With QuoteEdit or Delete MessageReport This Post
