Have you tried running some diesel through it and seeing if its more accurate? It could due to the extra viscosity of bio. Or maybe it could be calibrated for gasoline?
Yes I was right, I just downloaded the user manual for it from tuthill here: http://www.tuthill.com/admin/D...er_Owners_Manual.pdf It says it was calibrated using mineral spirits (very thin) and will need to be re-calibrated for other fluids. There is a calibration screw inside and that owners manual shows how to do it. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
