IP seals
Hi
My IP is leaking and the bosch seal kit is silicone. Should I be looking for a kit with viton seals?
Merk
2016 GMC Canyon, 2.8 4 Cyl Duramax
Location: Etna, NH | Registered: January 19, 2006Reply With QuoteReport This Post
Yes, Try Dieselgeek for the parts you want. He also has youtube videos to walk you through it.
http://www.dieselgeek.com/TDI_...it_p/pmp-fullkit.htm
Registered: January 21, 2009Reply With QuoteReport This Post
thanks Seadog
Got it there.
Merk
Did the job last night, went well and pump is sealed. So This was also an opportunity to look at the pump inards after 8 years of WVO usage. The inside of the pump was clean as a whistle. a slight tinge of color on the walls of the pump, but no crud at all. On top of the quantity adjuster there was a tiny bit of chicken skin built up on the metal parts, screws heads mostly where it could grab a holds in the slot. That was it. I cleaned that up and reassembled.
I am very conservative with switchover heat and longer purges. Don't get greedy.
Merk
