Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    FINALLY got the right temp...
Closed Topic Closed
hello all,
this conversion has beeen a great big pain in the butt. purchased car, invested 2k on repairs then IP starts leaking like crazy. got it repaired and installed/timed. reconfigured my layoout in the engine bay 3 times and now finally the temperature is making sense.
the setup is hot pickup in the middle of a a 5/8 alum coil. veggie tank is a hdpe bucket that has gotten as hot as the coolant 170F. after the hotpickup i have a 2" fuel filter, hoh to engine bay , fuel valve, fphe, filter, IP, fatjohn injection heaters. the temp before the IP is not 150F-165F. which is GREAT, Perfect, FIIIINNNNAAAAALLLLLLYYYYYYYYYYY. SO PAINFULL, BLOOD ALL OVER MY HANDS, WIFE SCREAMING IN MY EAR, AHHHHHHHHHHHHHHHHH.
now to the next move,
i had the plastick hdpe bucket as a tank but i want to replace it with a spray tank but i feel it will be a pain in the neck to add the coil and hot pickup so i will focus on only the hot pickup; copper coil wrap on furnace filter (10 micron) and 16 fphe.
since its a hoh insulated the hot coolant will heat the filter the enter the fphe (insulated) and finally into the hot pickup.
advantages:
* very fast setup/configuration
* 1 hole to drill in tank for heating/retrieving oil
* not wasting time heating the entire oil batch in the 16gallon spray tank. the fphe will be doing all the heating of wvo that will be used in a very compact area
disadvantages:
· hopefully you can provide those bec/ i am biased
evan
Jetta 96 1.9TD coverted SOLD
Jetta 2002 slowly installing frybrid kit Frown
Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, 18" RS4 wheels
Location: Montreal | Registered: 06 August 2005Edit or Delete MessageReport This Post
another
another shot
return temp
injector heat
Closed Topic Closed
