Many here have experimented with this. Using the Find button for furnace gives 357 threads here:
http://biodiesel.infopop.cc/ev...orum_scope=159605551 and find on babington (a type of burner using compressed air) gives 186 threads here: http://biodiesel.infopop.cc/ev...h&reqWords=babington I use a much simpler approach, a VO gravity drip system into a woodstove with a burner I describe in this thread: Simple VO drip into woodstove works good Also see the space heating section of burnveg where there are more threads. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
A burner I recently Built HERE
It's about as simple as I have seen for producing usable heat rather than just being able to burn oil in some fashion. It uses only Blown rather than compressed air and a drip feed. I don't like the idea of running compressors as they tend to be noisy, use a lot of power and running them continuously creates a lot of wear on them. If another drum were welded on the top of this basic burner setup with a chimney to take the combustion fumes away ( although it burns perfectly smoke free) and then 2 55 gal drums had the ends cut off and were placed over that and air blown between the 2, you could duct the air where you wanted it and have a VERY powerful shop heater that would be simple to make, cheap to run and heat large areas. You could also run it without the outer barrels but the thing throws a lot of heat and you would want plenty of space around it. With a 3 speed fan on the burner, you could also adjust the heat for a quick warm up then a lower heat for maintaining the warmth. **** * 1978 Merc 300D. Running Blend and 2 tank system with Home Made HE and water injection. |
The simple drip pot might be the way to go. Are there any pics?
There is a "heating" forum in the biodiesel section, it has many discussions about types of heaters burning straight veg. This links to my discussion describing the veg drip heater that I have used to heat my house for the last 3 winters, there are pictures. Check out the "military heaters on ebay" discussion there, it describes using a ready-made cheap military surplus drip burner unit for veg heating.
Yes there are pics in the thread I linked above, on page 2: http://www.burnveg.com/forum/viewtopic.php?t=42 I was inspired by Tim's thread where he has lots of pics. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
