Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Rabbit 1.6 WVO conversion
Topic Closed|
I would like some pics as I am going to convert my rabbit as soon as I get the title issues worked out
fothej@yahoo.com Thanks 86 F250 veggie since May 2005 25,000 miles and counting 78 Benz 300D converted Feb 2006 2,500 miles and no longer counting 92 F250 converted on May 2,2005 14 000 miles and counting 81 rabbitt 84 benz 300d |
did you use 5/8 tees or 3/4 tees with the 5/8 heater hose?
1983 Holiday Rambler 6.2 Banks TD 1987 Mercedes 300TDT 1984 Isuzu P'up 4x4 diesel 1983 Maxima wagon LD28 1985 D50 Ram 2.3 TD 1984 Isuzu P'up longbed diesel |
I used 5/8" tees the first time, which is probably where the problem was.We were running out of time so we focused on making that 9'section the best heat exchanger possible with lots of flow.I'm begining to wonder if I ever have to heat the tank.The IP only has to suck cold WVO through 16"of 3/8"line to the filter. Even when I get WVO from my 300 gal settling tank in the winter,it pours well.
3/8 copper line inside a 5/8 tee is very close.
I'm getting ready to use 3/4 tees with 5/8 hose. My old Benz I used 3/4 tees & 3/4 hose. It's only going to flow as well and the smallest/tightest point. 1983 Holiday Rambler 6.2 Banks TD 1987 Mercedes 300TDT 1984 Isuzu P'up 4x4 diesel 1983 Maxima wagon LD28 1985 D50 Ram 2.3 TD 1984 Isuzu P'up longbed diesel |
Yep... In my old Jetta, I used 3/8 tube for a fuel line. There was too much vacuum, and it would suck air past fittings. It helped a bit when I looped the return, but it only really worked well once I switched to 1/2 line.
jake ---------------------------- '99 Benz e300d (SVO conversion underway) '87 Samurai LWB - parts hauler & mule (ACME VW diesel kit, HoH, Pollak) ***Garage full of VW 1.6 + 1.9 bits... for sale!*** |
You can check out my 81 Rabbit conversion at www.frytech.blogspot.com . I used 3/4 inch PEX tubing for the coolant lines with 3/8 copper fuel line for my HIH. It has real good flow and heat exchange. You can see the valves I put in to either heat my tank or not depending on the weather.
JimB, very impressive, very nice work, lots of ideas you have given me. The use of ball valves and the homemade heat exchanger with the slide in filter heater are slick. I have a heated 12 liter tank in my Rabbit truck, in the same place as your heat exchanger on your car. My veggie filter is immersed in this tank, inside the coil, and attached to the inspection cover. Everyone's conversion is different, much to be learned.
Topic Closed
