I would tend to be worried about any water in the oil for corrosion reasons. Anyone know how the electronic water separators work on late model VW diesels? Would these work for veggie oil as well?
| Location: Boulder, CO | Registered: 04 October 2001 |   |
I just got my on-board pump-and-filter setup going last night, and got a cloudy look not due to water, but from the pump mixing a little air in. It cleared up a few gallons into the transfer, so I know it wasn't the equipment. The pump has clear tubing connecting it to the oil/water separator/filter, which I have hanging off the tank opening with enough fuel line going into the tank to couterbalance it. The separator has a clear (with its current age, slightly opaque) chamber on the bottom to show if water is building up and to allow draining off of said water - much easier than trying to dry out the oil after it's in the tank! Also, my oil has sat long enough for most of the water to sink to the bottom.
| Location: Vacaville, CA, USA | Registered: 22 February 2001 |   |
