Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    Single cylinder Yanmar on SVO?
Am thinking about getting a used Yanmar single cylinder generator to convert to SVO. The Kubota engine I've got does not do well at all on SVO. Does anyone know how the single cylinder Yamar does on veg?
Location: Yukon | Registered: June 15, 2017Reply With QuoteReport This Post
Do you heat the wvo or mix any diesel?
Location: Colorado | Registered: November 17, 2015Reply With QuoteReport This Post
No personal experiance of those particular engines but I've seen reports of ring gumming so I don't think it is a good idea.
My chinese genny has packed up after 2 1/2 years of hard running on B100 and I'm sure the rings are gummed (no compression) I think these problems come from higher running temps due to them being air cooled.
I use straight WVO heated via a system that used the engine coolant to heat WVO fuel lines (to and from WVO tank). Engine starts and stops on diesel. The Frybrid conversion kit was used on my Kubota powered generator, but the Kubotas don't like WVO I found out the hard way. I think they run too cool for proper burning of the WVO.
