Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Newbie needing advice...
Topic Closed|
member 2008 Sponsor |
Frybrid and Veggiestroke have just joined forces and the kit they come up with their combinced experience and R&D investments should provide a kit that fits your specs. Both are located in or near Seattle.
Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
you should read thru this link
http://www.frybrid.com/forum/showthread.php?t=4388 Omar www.omarsales.com |
Check Plantdrive.com they have a kit for this truck and have dealers across the country. All info on thier site.
Erick |
I'm in Boise area too, looking at Vegistroke in Portland area and Frybrid in Seattle. Interested in sharing local info??
It would be great to pool some ideas. PM me your contact info. 2000 F-350 7.3 Powerstroke Looking to convert to SVO. |
May I offer a suggestion? Rather than creating one monster tank, why not go with a moderate sized tank and have a second tank for filling on the road. I use the 60 gallon tank/toolbox from Northern Tools that Frybrid later adopted for their Powerstroke system. With 60 gallons and a tested 19.7mpg on WVO, I can get over 1100 miles.
In the future, I'd probably go with a smaller main tank. I've designed an in-tank heat exchanger that functions as a day tank so I don't try to heat the entire 60 gallon tank, but the larger the volume of the tank the harder it will be to maintain temperature. If I'm going to be going longer distances, I add as many 55 gallon drums as needed. You could build an aux tank that would fit between the wheelwells- 4' wide, 18" tall, 3' long- that would hold 135 gallons. That would put you at close to 200 gallons. The $99 Northern Tools 12v pump works great, even pumping cold oil. I've used this up in Maine but it was only 25 degrees. Todd 2002 F-250, 7.3l PSD on grease since 2004 |
Excellent suggestion. I am looking into the tanks now. I often drive 1800 miles in a single trip and am not to hot on losing the bed space, but am willing to sacrifice some of my fishing gear for better performance, etc. Do you have the specs for the aux tank or a place where I could buy one? 2000 F-350 7.3 Powerstroke Looking to convert to SVO. |
Topic Closed
