Biodiesel and SVO Forums Home
Forums
Straight Vegetable Oil (SVO) as fuel
General SVO Discussion
Dieselcraft centrifuge works great -My filter and dewater rigGo ![]() | New ![]() | Find ![]() | Notify ![]() | Tools ![]() | Reply ![]() | |
| Member |
We both are using junk power steering pumps, but JOAT mentioned a 12V Mallory fuel pump that would probably do the right flow 0.9gpm and 90 psi pressure. If not that there are plenty of other gerotor and vane pumps you could choose off the shelf. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
It uses a bronze bearing that is the full height of the rotor (about 3") and the oil comes out inside the bearing, lubricating it well. (the friction is so low it continues to spin for several minutes after you shut off the pump) I think it will last a long time, but haven't seen any data anywhere. The 18 wheelers that use this often run 24 hours a day so they put a lot more hours on them than we ever will. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
To clarify it doesn't dewater like a centrifuge does (in the rotor), it does dewater like Tim's flash evaporator by passing hot, high pressure oil through the 2 small orifices. And it is producing lots of visible steam at a much lower temperature (120F) than I expected. (edit- see page 12, it does dewater like a "true" centrifuge but it keeps the water in the rotor, it may be possible to remove water/acids/etc. without a mistwash if you capture the output at pump shutoff)This message has been edited. Last edited by: SunWizard, YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
It's hard to get pictures of steam, but you can make out some of it in this pic. Yeah, cold oil quickly fills the Centrifuge with hydrogenated and animal fat. | |||
| member |
so it seems that this would not be suitable for one tanking or blenders who do not get thier oil up to temp before their onboard filters, unless they cold filter thru a sock filter first, maybe. besides, it seems that the added heat is really benificial to dewatering. JOAT, do you mist/bubble wash first? Be the change you hope to find in this world.-Gandhi | |||
| Member |
So far I haven't ran a mist washed batch through the centrifuge, just heat settled and some barrel bottom junk. I'm still experimenting with mist washing. Not really seeing any PH change in the water when I do, and it's a pain with partially hydrogenated oil. Will play with a mist wash batched in a week or two Next batch will be a baking soda neutralized heat settled batch (heating as I type), then a magnesol batch. I'm curious to see how well it removes those type powders from the oil. | |||
| Member |
Some or alot of your baking soda should not be powder any more cause it reacted with stuff in the oil. Matters how much you put in. Magnisol..... not sure if that stuff is intended to be a reactant like the base in baking soda would or if it something intended to ABSORB or Surround particular things in the oil. This will make a difference on how it ends up getting spun out. Looking forward to your report(s) _________________________ If you believe you can't YOUR RIGHT; But equally so.... if you believe you can, YOUR RIGHT as well. | |||
| Member |
I solved the sealing of the water heater elements. Use a 1/16" thick by 1.25" ID metal washer first on the element, then a 1.5" ID washer with a 1/8" x 1.25" O-ring inside. The bigger washer acts like a retainer, preventing blowout. This seals great and has handled the high temp and pressure used with my rig. So now I am using 2 - 4500 watt heater elements which gets the WVO hot real quick and makes both the centrifuge and the flash evaporator functions work better. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| member |
wizard- are you using any temp controls, or just running 2 4500 w elements on 120v= 2250 w total, @ 55 gph? any idea of exiting temps,how well it dewaters? good idea on reinforing the o-ring. Be the change you hope to find in this world.-Gandhi | |||
| Member |
No temp controls just the 2 elements at 120v=2250w as you say. Exiting temp starts at 100F, and goes up to about 200F after 2 hours. Seems to level off around there due to losses to ambient 50F through the 55 gallon metal barrel, pipes etc. Dewaters very well, I can see and hear the steam coming off the outlet of the centrifuge, and when it stops steaming it has passed the pan test for water each time. 3 batches so far. Seems like 4 passes through the centrifuge is a good amount for both dewater and to get the oil very clean. edit- and this is after a mist wash where I drained off most but left some visible water in the oil. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
I made another improvement to the design of this rig. I drilled a 3/4" hole about 6" down from the rim, and ran the supply pipe to the centrifuge through there, and didn't bolt it to the barrel. This made it much quieter since the drum doesn't resonate anymore. It also means you can save $30 by not buying the mount with the centrifuge. edit- It also means I can put a lid on the drum without taking off the centrifuge like I had been doing. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
I had a PM asking for more detailed pics so here are some more. Centrifuge in the barrel. The Tee before it is the pressure relief valve with a plastic elbow over it to direct the flow down: Here is the first heater element: Second heater element (showing the metal washers that hold the o-ring in place): Parabolic concentrating 2'x6' solar collector (not needed with the 2 water heaters, but fun!) YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
How practical would this be for on board filter/ dewater? Anyone working on it? | |||
| Member |
Very practical, it would be easy to convert this to an onboard setup. I don't plan on doing any long trips soon where I need the onboard, but may make a portable version anyway because its easy. Use a 12volt motor on the pump. Use whatever heat source you like, coolant heat, wvo or propane fired heater, or a 110v generator powering water heater elements. Put a small fan blowing across a cross fitting (to the outside of vehicle) just below the centrifuge to help the dewatering. If you plan on mistwashing, you need to heat first, which I do while running through the centrifuge for the first few passes. Then mistwash, leave it settle at least an hour, drain off the free water, then start the centrifuge, which would work fine even while on the road. And you can do it all in 1 tank which is what I have been doing with the barrel. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| Member |
Why mist wash? Shouldn't the centrifuge remove everything including food particles, carbon (from the hi temp frying), water and the soluble acids? Or does the acid stay behind? One tank sounds great but I am having trouble visualizing how that would work. Are you drawing from and filtering into the same tank? | |||
| Member |
Mist wash is because its evaporative dewatering so acids/sugars could stay behind. It works like a flash evaporator. Many people report success without doing it but I am extra careful. My mist wash water always comes out clear and neutral PH so I tend to think its not needed, but it depends on your oil source. Thats the trick, you never know if theres bad stuff in there so its safest to always wash, especially on the road with very unknown sources. (edit- see page 12, it does dewater like a "true" centrifuge also but it keeps the water in the rotor, it may be possible to remove water/acids/etc. without a mistwash if you capture the output at pump shutoff) Yes I draw from the bottom of the tank and centrifuge dumps into the top of the same tank and I find 4 passes through the centrifuge gets it amazingly clean. Edit - and I calculate 4 passes like this, 30 gallons of VO, at 1gpm this runs best at, is done in 2 hours. Sometimes I do more passes than this because some time is spent heating the oil and I run through the centrifuge during this too but I don't count that since it doesn't work near as well cold.This message has been edited. Last edited by: SunWizard, YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. | |||
| member |
I would like to thank you for the positive feed back on the Dieselcraft Centrifuge. We would like to use your photos and your comment on our web page. Awaiting your reply:-) | |||
| member |
I would like to thank you also for the positive feed back on the Dieselcraft Centrifuge. We would like to use your photos and your comment on our web page. Awaiting your reply:-) | |||
| Member |
Mr Dieselcraft, I am contemplating getting one to play with. Will you be offering special pricing for forum members? Where are these units made and what is their life expectancy? Also do you see any problems using this for dual purpose? 1. lube oil filtration normally 2. After cleaning the centrifuge and switching quick coupling hoses, WVO filtering? then back to 1. after cleaning. 2 birds with one stone - | |||
| Powered by Social Strata | Page 1 ... 4 5 6 7 8 9 10 ... 177 |
Forums
