Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Hey,
These centrifuge filters sound like a geat way to filter veg without throwing away expensive 10 micron absolute microfiber filter bags! But do they really remove water? Doesn't really matter if they can take out solids etc.. For my needs I filter hunreds of gallons for the vehicles I service. The largest size Dieselcraft centrifuge does 5 GPM and is only $1399.00 through vegpower.com the best source I've found for cheap WVO filtration components & products etc.. Here is the link to the OC-200 ... http://www.vegpower.com/order/prodpage.cfm?cat_selected...ected=513&startrow=1 Very interesting discussions btw. Cheers! 98 VW TDI, 62,000 miles on Waste Veg Oil CENTRIFUGE-200.gif (32 Kb, 67 downloads) Dieselcraft OC-200 |
Here is the results from my 2nd run on an OC-20 (thanks Gary) I am less than excited about this as a way to meet my cleanliness specs for my D Max in conlusion I think it will work fine if you run an older Diesel where 10 mic is all you need. The OC-20 does not have the particle holding capacity to run for long periods without throwing off the particulate back into the VO (see the rise in 9 pass). So multiple pass is out of the question. Since I have spent about $100 in testing to get to this point I am going to go back to my original idea of kidney looping through filters to do a final clean up on my WVO so I can run it in my D Max and not be plugging up 2 mic filters every 300 miles. Was a fun leaning though. Possible the larger ones would work better with holding capacity but have no way to verify this. Thanks all for the feedback on this if you have any other conclusions that I have missed let me know Thanks
2006 LBZ Duramax CC/SB,Line-X,Advance Fold a Cover, 2WD, 4" Aero Turbine Exhaust, Isspro Gauges A Pillar,Westin Nerd Bars. 19 MPG City, 22.5 MPG Freeway Greasecar Kit with Automated Controller,200 gal WVO tank. Time to go fishing, Now I pass everything including the fuel station. VO_Particulate_Report2_(Large).jpg (41 Kb, 80 downloads) |
It was at 60 PSI. I don't think the pressure would change the results that much. Maybe by volume but certainly not by ratio between passes. As I say in my post I do think its over capacity to hold the particulate and its going back into the VO. No Photos just lab results you cannot see with the naked eye the micron sizes we are talking about. The numbers in red on the report are the particulate count in Parts Per Milliliter in each micron size. 2006 LBZ Duramax CC/SB,Line-X,Advance Fold a Cover, 2WD, 4" Aero Turbine Exhaust, Isspro Gauges A Pillar,Westin Nerd Bars. 19 MPG City, 22.5 MPG Freeway Greasecar Kit with Automated Controller,200 gal WVO tank. Time to go fishing, Now I pass everything including the fuel station. |
I agree the human eye cannot see the micron sizes quoted, however, if there is enough of it captured in the CF, then it will be visible as a smear or a lump no?
This pic was from the first set of tests I did.Dated 1/1/07 2006 LBZ Duramax CC/SB,Line-X,Advance Fold a Cover, 2WD, 4" Aero Turbine Exhaust, Isspro Gauges A Pillar,Westin Nerd Bars. 19 MPG City, 22.5 MPG Freeway Greasecar Kit with Automated Controller,200 gal WVO tank. Time to go fishing, Now I pass everything including the fuel station. 3passrotorcln.JPG (902 Kb, 107 downloads) |
I don't think the particle holding capacity is your issue. It can hold enough particles to make a 1/2" thick layer of compressed black goo inside the rotor, and always does when I run it. 90psi makes a large difference for me.
You are running it on such clean VO that almost nothing is on the rotor, though you don't show the inside surface of the rotor cover where most of the stuff would accumulate (if you had any.) Thats the other reason I know you are nowhere near the particle capacity. With no buildup on any of the parts, most (>1/2) of what you filtered would drip out as the rotor slows down, and would not remain inside to look at. Do you have a pic of what the VO you captured at slowdown looks like? (if you captured.) If you really want to see what it can do, and is most useful for, you should run the VO through it before you use any other filters. Then you would see you could eliminate replacing 2 or 3 of the other filters you are using. Then do a 1 micron absolute after the CF to get it down to the level you need for the Dmax. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
My limited experience is exactly as Sun has described, the dark brown deposit is stuck, almost like it is dehydrated against the rotor. And as I mentioned, that was at 70 to 80 psi.
I believe the particle test Sun did showed your filtering, following centrifuge, should be targeted toward the under 5 micron. (seems I read somewhere that the under 5, or under 7, was the most abrasive too?) Sam 2002 F250 Vegistroke now with the new V3 module! |
The increase in particulate is curious. Do you think that you may have contaminated the 9-pass sample during your transfer procedure somewhere? Maybe the hoses you were using was contaminated. Is there a possibility that you may have mislabelled the samples? How about your shutdown procedure, you may have contaminated it during shutdown. The increase appears to be unexplainable to me otherwise. As Sun pointed out, the dirt carrying capacity is not the issue. There is enough space in the rotor to hold whatever dirt you have. Thanks Jojo In matters of principle, stand like a rock; in matters of taste, swim with the current. ~Thomas Jefferson ---------------------------------------------------------------------------------------- 1996 Mercedes E300D "Maybelyn" 2006 2500 GMC Savanna Cargo Van "Vinny" (2006 LLY Duramax with 4L85E) |
More info, 90psi is about 10x the filtering ability in my tests compared to 60psi, thats what I mean by a large difference.
The best explanation I can think of for the increase in particles you saw in the 9 pass test would be you got some of the output at slowdown which contains concentrated particles. Even if the CF was doing no filtering at all (exceeded the capacity), you would see less particles after running it, since some stayed in the rotor, not an increase in nearly all sizes as you showed. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
I just don't think its ready for prime time yet to meet the Hydraulic ISO spec so am going back to improved filtration and kidney looping to get where I need to go. Cat is the leader in filteration with Hydraulics and the new diesels and if they don't use a CF then I will take their engineering expertise on this one. I will let someone else do all the testing at the low micron sizes to see if they have better results. Would be great to see success with this but at this point I am not a believer. 2006 LBZ Duramax CC/SB,Line-X,Advance Fold a Cover, 2WD, 4" Aero Turbine Exhaust, Isspro Gauges A Pillar,Westin Nerd Bars. 19 MPG City, 22.5 MPG Freeway Greasecar Kit with Automated Controller,200 gal WVO tank. Time to go fishing, Now I pass everything including the fuel station. |
The flaw in your logic and your tests are this: You took VO that is filtered through 4 other filters to <1 micron. Lets say you ran through another 1 micron absolute filter, then examined the filter and run lab tests, if it didn't get any more out you call that a failure? All it shows is you have clean VO. Since you started with already finely filtered VO, your results tell us only its not removing particles < your 1 micron absolute filter in 9 passes at 60psi. That agrees with the tests I ran about 10 pages ago in this thread, but we don't know to what micron level it would remove to in your rig without the 4 other filters first. I feel its a shame since you are the only other one running particle count lab tests so far, it could have given us some more useful data points to compare to the tests I ran. But not with the way you ran your tests, because of all the other filters. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
Seems that the MFG should be providing such test data to market thier product, With all the varibles everyone keeps coming up with to provide reasons the data was the way it was, Which is one more reason why I am skeptical it will not work for my application. So since this is my last comment on this, everyone that has a 10 mic requirment it will work just fine. Go for it you won;t have to change filters as so many proclaim. I am just after something different than most greasers so don't kill the messenger The data don't lie. End of this story.
member 2008 Sponsor |
Has anyone come up with "the perfect pump" to run this thing? I have bids in on a couple teel pumps, but if a PS puimp will do just as well, and it will hold up, then that would be good.
I also have a question: The pressure relief valve will keep the pressure to whatever it's set at (90psi), and any pressure over that will be dumped out the valve. Does this mean if I put a 3gpm at 100 psi pump on the system, the relief valve will dump the extra 2GPM the CF doesn't use, and keep the pressure at 90psi ? 1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1996 Suburban, 2 tank conversion. 1997 E300D awaiting conversion |
Sun, I am going to send some samples for testing. Where did you send this to? How much did it cost? How did you send the samples, did they provide sample containers to send the WVO in? How long did it take for the results to come back? Thanks Jojo In matters of principle, stand like a rock; in matters of taste, swim with the current. ~Thomas Jefferson ---------------------------------------------------------------------------------------- 1996 Mercedes E300D "Maybelyn" 2006 2500 GMC Savanna Cargo Van "Vinny" (2006 LLY Duramax with 4L85E) |
I've been thinking on how to improve Dieselcraft operation. If we do not heat the WVO as high, maybe we can achieve more Centrifugal dewatering than Flash Evaporation dewatering.
I am speculating that 80-90*F WVO would not flash evaporate and hence, most water would be removed by centrifugal action. Any thoughts? Thanks Jojo In matters of principle, stand like a rock; in matters of taste, swim with the current. ~Thomas Jefferson ---------------------------------------------------------------------------------------- 1996 Mercedes E300D "Maybelyn" 2006 2500 GMC Savanna Cargo Van "Vinny" (2006 LLY Duramax with 4L85E) |
I sent samples to www.herguth.com, I don't know what it cost since Dieselcraft offered to pay. I used 20oz. plastic water bottles, and it took 1 week.
Its a trade off since 120F is where the particle removal and centrifugal dewatering starts. I get nearly all the water removed by centrifugal action at 120F as long as I stop it after 1 pass and empty the rotor. Then I run it hotter (160F) for the rest of the passes for better particle removal. I prefer to do a mini-mistwash to check for acid/salt/etc and if none is present (or if I mistwash so none is present) then there is no drawback to run it hot (160F) and dewater and filter as fast as possible. Like so many things, it depends on your VO, and how much water, and if its PHO you may need hotter. Mine so far was all non-hydrogenated soy, but I am going to run some PHO soon. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
question: The pressure relief valve will keep the pressure to whatever it's set at (90psi), and any pressure over that will be dumped out the valve. Does this mean if I put a 3gpm at 100 psi pump on the system, the relief valve will dump the extra 2GPM the CF doesn't use, and keep the pressure at 90psi?
Anybody? 1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1996 Suburban, 2 tank conversion. 1997 E300D awaiting conversion |
Yes if you have a relief valve that opens wide enough. I think the small grainger valve I used would not let that much bypass, but I don't have a pump that puts out that much to test it.
| Previous Topic | Next Topic | powered by eve community | Page 1 ... 30 31 32 33 34 35 36 ... 149 |
