Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    Dieselcraft centrifuge works great -My filter and dewater rig
Page 1 ... 131 132 133 134 135 136 137 ... 178
Originally posted by scoutsdad:
I just ordered a FilterFuge FF60. The price has gone up - $295 + $20 shipping.
Because I am an idiot, I still cannot get a grip on the motor and pump needed. Clearly, I want a gear pump. The centrifuge manufacturer wants 2 gpm and 90 psi.
I contact Suplus Center to couple up a gear pump with a motor to meet the above specs. The tech recommended 9-7145-B (pump) and 10-2367 (motor). My concern was that the specs for the pump said "Pressure 3625 PSI max." Paul at FilterFuge (very helpful) said the psi was way too high - the pump would not work correctly. While the recommended 1/2 hp motor may be overkill, there is no reason it would not work.
I'm a pencil pusher with no relevant experience. So, here are my dumb questions.
Does the pump have to be designed for oil or will a water pump work?
Do I need to find a pump with specs of 2 gpm and 90 psi?
Will any motor work so long as it has sufficient hp, ie too much hp won't hurt so long as I get the right rpm?
Can standard motors / pumps be adjusted to regulate the gpm and psi?
Do the relief valve just allow a diversion of enough fluid to maintain the proper psi? So, if the psi is far too high, most of oil will return untreated to reservoir?
All help is appreciated.
Correct, these pumps build pressure if they have something to pump against, in the fuge there are two nozzles that the oil jets out of which causes the high speed rotation, these nozzles are pretty small so they will build pressure, so you need a pressure relief valve and/or a ball valve to set your pressure to the correct psi, the extra oil just vents out of the valve back toi the tank.
What have you guys experienced with taking the bypassed oil and reintroducing it into the intake of the pump?
Seems to me this would eliminate the recontamination of the oil.
Location: Andover, MA | Registered: December 30, 2007Reply With QuoteReport This Post
Originally posted by fabricator:
Anybody know what the OC50 is going for these days?
$499 with the base, 2 tees, guage, valve, 2 hose barbs.
95 Dodge Cummins 4x4
That is OK but it doesn't eliminate recontamination.
An idea to avoid recontamination using one 55 gal open top drum:
Direct the CF drain and bypass oil into a 55 gal garbage bag "floating" on top of the oil. When the bag is full, lift the bag from the bottom (using a string and marble tied to bag bottom previously) to empty oil back into the drum and start over. Same idea as a bladder in a water pressure tank except it's not pressurized. Downside is you have to be there to tend to it.
Now that I think about, the oil that bypasses the CF isn't any cleaner than the oil picked up from the tank anyway. Really, one would need to direct the oil exiting the CF to the intake, and that would reduce the water removal.
Sam
Location: Wyoming | Registered: July 25, 2006Reply With QuoteReport This Post
If piped so only clean oil enters top of barrel from the CF, would the warmer cleaner oil from the CF sit on top while the cooler dirtier oil tend to sit lower in the barrel offering a bit of separation thereby reducing the amount of recontamination?
Sam
I had an old dishwasher pump sitting around that I put on the drain port of my barrel. The pump intake is 2" so it fit perfectly, and it has a 3/4" port off the side of the intake housing where I draw oil for the hydraulic pump that feeds the CF.
The output of the dishwasher pump is run over and back up in to the bottom of the barrel along the edge with an elbow inside the barrel to direct the flow to turn the oil in the barrel cyclone style.
I put the dishwasher pump on a timer so that it cycles for a minute every 15. It keeps everything mixed up and makes sure it all gets through the CF a couple of times.
Registered: April 11, 2008Reply With QuoteReport This Post
The law of physics says it would.
Six months after I constructed the CF Sunwizard designed I have put my first Eight (8) Gallons in the 55 gallon drum. Eight Gallons for several reasons. I want to make sure there are no leaks on the seams before I get going. Secondly, the bottom quarter of the cubie is cloudy so I stopped pouring at that point. Do you guys dump in everything or pick off the top? What is the cloudiness. Lastly, I think I will run the first eight (8) Gallons through the piping to clean it out. I used Real Tuff teflon paste and I am sure some of it is on the inside of the pipes along with whatever else comes inside cast iron pipes. Should I be concerned about teflon paste at all? Should I even run it through the CF or just run it through the piping then dump? Is there any concern about a rusty barrel?
Sorry for rambling but I am so excited to begin this journey that I have only read about from you guys.
If I seem frantic it is because my mother's day gift, on Sunday, to my wife is giving her and my son a ride in the truck powered by Veggie Oil. It is the least I can do since I have been a recluse in the garage for Six months.
My motor came with no pulley or shaft. Just a slot that looks like a flat head screwdriver will fit. My hydraulic pump came with just a shaft.
Where do you get the pulleys and shafts???
Registered: September 10, 2006Reply With QuoteReport This Post
A motor with no shaft??
Can you post a pic?
Registered: February 11, 2008Reply With QuoteReport This Post
Why do I think that she may be seriously underwhelmed by this?
Thats a Carbonator motor, they need a special coupler, here is some on ebay for $5 and a special type of pump with no shaft and the same kind of slot. Most carbonator pumps are vane pumps so don't work as well.
The pump is a gear pump, but where do I get the pulleys??
Tractor Supply , Grainger, McMaster-Carr
1994 F250 IDI 7.3 NA E4OD
Remember that the forum search/"find" feature does not include the archives . Search the forum archives here-
http://www.biodieseldiscussion.com/forums/search.php
Registered: November 08, 2004Reply With QuoteReport This Post
You can't put a pulley on that motor. That motor will not work with that pump, as I explained above.
Why will it not work?? The spec are below:
Baldor spec# 34G40X17
1/3 hp
115 volts
6.6 amps
1725 RPMs
Is this a better motor??? It has 1/3HP or do I need more?? it is 115V and has 100RPMs??? What are the minimums the motor needs to be??
http://cgi.ebay.com/FASCO-ELECTRIC-MOTOR-1-3HP-115V-105..._trksid=p3286.c0.m14
That depends on what CF and what pump you got.
  Powered by Social Strata Page 1 ... 131 132 133 134 135 136 137 ... 178
