Home
Forums
General SVO Discussion
Hi Michael, I have two rotors for my OC-50, one seems to rattle a bit more than the other, but both rattle until they get up to speed, then the hum over takes the rattle. I don't let them get real dirty since it gets harder to clean them when the goop gets compressed and hardens. You should clean it and try again to see if it sounds the same. I'm assuming you have it up to 90 psi too? Sam 2002 F250 Vegistroke now with the new V3 module! |
Sam,
Yes, an Oberdorfer 991 keeps the pressure at a consistent 90 pounds even when the temp is about 160 degrees. No matter if the centrifuge is clean or not, the rattle remains. I am thinking that I will contact Mr. Dieselcraft and get his take on the rattle, too. (I have lined up the marks to be sure that it is put back together correctly.) Sam, or anyone: Any ideas on what to do to lessen the noise? Could it indicate that some harm is happening? One other question, when the filtering is done, the oil is nice and transparent with a golden color. After cooling to room temperature, the oil hazes a bit. I have been spinning the centrifuge for about 2 - 3 hours. There littel or no more sediment in the bowl in the last hour. Should I do more maybe? Michael |
Mr. Dieselcraft,
Any ideas on the posts regarding the rattling noise? Dangerous? A bad sign? (I listened to your You Tube entry with the OC-20 and did not hear any rattling.) The unit is new and has not been abused. Any help would be most appreciated. Michael |
If the oil gets a haze when it cools I would guess there is some water in it.
Hi Raften, It really depends on the type of oil, or even a mixture of oil from different restaurants. I pick up mostly hydrogenated oils, and even when its completely dry after the CF it is still creamy at room temp. Sam Sam 2002 F250 Vegistroke now with the new V3 module! |
Good idea email him at: sales(at)dieselcraft(dot)com
Maybe noise is too subjective, mine is noisy when you stand next to it, but it is in the garage so you can hardly hear it from the house. So, I'm not sure how much more or less your CF is producing noise than mine. But, I'll have mine going the day after tomorrow, if you want, I'll call you, or you call me, and you can listen over the phone if that would help you. I know mine is doing its job as it has for months.
Do you see some wear, or bump marks on the rotor?
Your CF is an OC-50 correct? And you are cleaning 45 gallon batches, or do you have a larger tank? First, regarding the haze, it depends on the type of oil, and how cool is cool. In that last hour you haven't really gone through the entire batch since it is constantly mixing and if your oil is relatively clean when you start it wouldn't be too surprising you don't see a lot of sediment in that last hour. To put it in perspective, if I run my oil for 48 hours, on an 80 gallon batch, cleaning the rotor 4 times, I can start hour 49 with a clean rotor, run for another 8 hours and get just shy of another teaspoon of black deposit. (the value of removing that last bit with the CF is debatable, but it's in the oil and it doesn't burn in your engine) Sam Wyoming 2002 F250 Vegistroke now with the new V3 module! |
Gang,
I am about to order a OC-50 Here is my design. Pick it apart. Tell me where I am wrong. I am going to use the centrifuge for BD production for both its dewatering/flash evaporation and for its particle removal. I need to process 120 gallons / week, but I don’t want to spend every weekend in the bio-shed processing oil. (actually the bio shed is called ‘the litter box’ on account of the quantity of kitty litter everywhere.) I’ll do some filtering down to ten or even one micron and then move the oil into the 275 gallon tank where the centrifuge can continually clean the oil for days on end. It is my intent to start the centrifuge up and check on it every few hours in the beginning to clean the rotor, but then after the first day check on it before/after work and just let it run autonomously. I figure two to three days of continual filtering will give me clean and more importantly, dry wvo. From there I’ll process once every other week. Is there a need to plumb with pipe greater than ½ inch - since that is the input on the centrifuge and the output on the bottom of the tank? Pump: It looks like folks favor the Oberdorfer style. I’m flexible there. Looking for a critique. While the attached drawing isn't exactly to scale, you should get the general idea. Thanks Greg 2004 Dodge 3500 Cummins - 2008 F-350 w/ DPF delete - Four Farm Tractors - Two Homes. All on B100 centrifuge.jpg (37 KB, 80 downloads) |
Looks good except the thermostat should be mounted touching the top of the heaters pipe. This way even if the pump shuts off, then the heaters shut off instead of overheating.
You only need to filter to 100 microns before the CF, any lower is a waste of filters since the CF will remove it better. You probably won't need to run it for several days, since bio is thinner than VO it should filter and dewater much faster. 1/2 plumbing is fine except after that CF you need 1.25" YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
Thank you for reviewing it.
In your notes on xycworks.com, specifically when plumed to a hot water heater, you have the output of the CF going right into the tank with a vent hanging off the side. I assume the vent is there for evaporation purposes? Can I plum directly back into the tank or is the open funnel idea a better one? I am going to be using the CF before I process for BD. So it will be cleaning the VO before I turn it into BD. Who knows, I may also just use some straight VO in my tractor during the summer months. It is the dewatering aspect of the CF that has me the most intrigued. 2004 Dodge 3500 Cummins - 2008 F-350 w/ DPF delete - Four Farm Tractors - Two Homes. All on B100 |
Mr. D. wrote me and is going to change out my rotor. (Great service and response.) QUOTE] Any ideas on what to do to lessen the noise?[/QUOTE] I'll have mine going the day after tomorrow, if you want, I'll call you, or you call me, and you can listen over the phone if that would help you. [/QUOTE] No need to call as I will get a new rotor and then I can determine is there is excess noise. Do you see some wear, or bump marks on the rotor? No.
Your CF is an OC-50 correct? And you are cleaning 45 gallon batches, or do you have a larger tank? First, regarding the haze, it depends on the type of oil, and how cool is cool. In that last hour you haven't really gone through the entire batch since it is constantly mixing and if your oil is relatively clean when you start it wouldn't be too surprising you don't see a lot of sediment in that last hour. To put it in perspective, if I run my oil for 48 hours, on an 80 gallon batch, cleaning the rotor 4 times, I can start hour 49 with a clean rotor, run for another 8 hours and get just shy of another teaspoon of black deposit. (the value of removing that last bit with the CF is debatable, but it's in the oil and it doesn't burn in your engine) [/QUOTE] I thought that 2 -3 hours was enough with ny OC 50 and 40 or so gallons. (I'll check back through the posts to get a handle on this.) 40 hours! wow. The cloudiness ocurs in a small sample jar when it reaches room temperature. Other thoughts? My thanks again to all. Michael |
DieselCraft has great service, and it certainly adds to the value of their products. Sam Wyoming 2002 F250 Vegistroke now with the new V3 module! |
Greg, (I just noticed my first comments to you have not been posted, I'll give it some time then repost. But my comment below assumes you saw my first response.) Something I neglected to add. You should consider buying a second rotor, that way you can switch them out and restart the CF, then clean the dirty rotor at your convenience. In fact, it helps to soak the dirty CF in hot soapy water for a couple hours before scrubbing out the goop with a plastic pot scrubber. (Dry good and squirt WD-40 through the jets and you'll be ready to do the switch again. You should plan on doing the first cleaning after the first 2-4 hours after the start, then you'll have a good idea how long you can let it go before the second cleaning. Sam 2002 F250 Vegistroke now with the new V3 module! |
I know I have a CF slightly larger that you OC50. (SpinClean FF60) I believe the Nozzels in your 50 are considerbly larger than the OC20, if like mine they will pass a piece of 14 gauge copper, to clean them. Then you can do a lot corser job of presreening prior to your Cf. I use the following from McMaster Carr Part # 98755K54 (Same as 98755K14) Mini PVC/Stainless Steel Suction Strainer 30 Mesh, Fits 3/4" NPT Male, 304 SS Screen In stock at $3.12 Each The above screen is all I pump my oil threw when filling my CF drum. Your milage may vary depending on the pressure applied to the consumtion peddle! Ken In Central NY Flyboyd8, Central NY 93 f250, 7.3 N/A, ext cab, >103K+ on veg (5-06 DIY conversion) FASS HDPP on Veg, Facet 59SV for diesel. 100 Gal. veg tank :-) >283K total. Three winters on veg with DIY system. converted. in 5-06, "NO Fancy Gizmo's", it came stock with all the power I need. Long Live the IDI!!! Join the NRA today! Freedom was never free! thank a Vet!! |
The open funnel is much better for evaporation, and how I operate it most of the time. Open is not good for a mobile holy grail version or water heater which is the pic you are referring to. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
I ran a test on the CF today. I mixed 2 heaping tablespoon of salt into 12 oz hot water and poured it into a ½ full cubie of previously filtered WVO and shook it up till emulsified. I tasted a droplet of the concoction on the tip of my tongue and could definitely taste the salt. I then CF this ½ cubie of wvo salt water emulsion at 160F till there was no more water vapors from flash evaporation. Then captured rotor on shutdown and this is what I drained out of it.
The white flakes tasted very salty. There was very little free water. Most of the 12 oz of salt water was flash evaporated, not captured in the rotor. I took the rotor apart and found more salt. I ran the CF for another 45 min to see how much more salt would be captured and got a little more. This is good news. I was going to do sugar next but I know what the outcome would be so I think I am going to skip it and do vinegar next. Edit: I drained the CF'ed oil into a clean cubie and will let it settle then taste the bottom and see if any more salt. |
Interesting Canola, so do you figure you recovered the two tablespoons of salt? I have a Mexican restaurant that just started using some spice that is very fine, easily plugs my pre-wash screen and burns my eyes when I stand over a warm batch of it. I just finished loading the last of 150 gallons I picked up on Sunday. I think I'm going to need to do something a little different to make it easier and quicker to remove the spice. So will my truck run hot on capsaicin oil? <g> Sam 2002 F250 Vegistroke now with the new V3 module! |
No way to tell since the salt is in a different form than it went in. It went in as crystals, it came out a different color. Maybe it's more concentrated (compacted). I'll let the oil settle a week or so then taste the bottom and see. I did taste the CF'd oil and did not taste salt. Question: Do you run the oil through a polishing filter after CF? If so, what micron and how long does the filter last? |
If by polishing filter you mean multiple cycles through a filter? Than the answer is no. After the CF I move to a holding tank unfiltered, or pump into my truck or cubies, filtered through a 2 then 1 micron filter. Last spring I cut a couple of those filters open and the were perfectly clean, so I haven't replaced the two since, and they've had 2-3 thousand gallons run through them. Unless someone knows of 1 micron absolute filters cheaper than 50 dollars, I don't think I'd save money cutting the CF time and relying on a filter. However, we are slowly moving, and our new place doesn't have a garage, so I'm going to turn part of an old calving barn into an oil processing barn, the problem is there is no electricity so I figure I'll be running everything off a generator (on vegoil), this will change the price of electricity and make a 1 micron filter a better value. One thing kind of bothers me, I'm not sure that the ultra fine particles that are removed during the last half of my CF runs would get filtered out by a 1 micron absolute filter. And that begs the question; How much/what effect does a teaspoon of non-combustible carbon per 80 gallons have on a vehicle. How much gets blown out the exhaust and how much ends up in the engine oil? I'm sure the answer would depend on the vehicle, but for now I'm happy to error on the clean side. Sorry, I kind'a drifted subject wise on this one. Sam 2002 F250 Vegistroke now with the new V3 module! |
It's been my understanding that oil when circulated through the CF for a sufficient amount of time is going to "polish" it to something around .5 micron and that doing so is most likely not necessary. What is the range of filtering ability in fuel filters?
I confess that frequently it is beyond my capacity to follow the jumbled mix of thoughts in this and other threads. The best I can hope for is to not get beat up to badly for asking questions for which smarter folks have already been able to extract an answer. |
| Powered by Eve Community | Page 1 ... 115 116 117 118 119 120 121 ... 156 |
Home
Forums
