Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    Using oil by-pass filter for WVO fuel filtration?
Closed Topic Closed
I came across this site after seeing an ad in a diesel magazine.
http://filtrationsolutionsww.com/
Do you think it can flow enough WVO to fuel an engine?
Masochist to Sadist: "Hurt me."
Sadist to Masochist: "No."
It's a bypass-type oil filter - only a sidestream of the oil goes through it, the rest still goes through the stock full-flow oil filter (and most of those bypass when too restricted.) So, no, it wouldn't flow enough, probably, unless it was on a VW Tdi or something similarly miserly, fuel economy-wise.
Craig
www.PlantDrive.com
1972 Land Rover Defender/Series Hybrid, 300Tdi, Two-Tank PlantDrive system: HotFox, Vormax, Vegtherm Standard
Wife's car: 2001 VW Tdi New Beetle: PlantDrive TwoTank system: Donut tank for start-stop, VegMax, Vegtherm standard, 3-3-port valves, controller
Location: Berkeley, California, USA | Registered: 04 March 2002Edit or Delete MessageReport This Post
For use as a bypass oil filter, the oil inlet has a restriction, to limit the oil flow thru the filter. In a fuel filter application, the restriction is drilled out to allow maximum flow thru the housing.
Whether you wish to rely on TP to ensure that your IP does not get trashed, or not, is up to you.
I recommend the installation of a 5-15 micron rated fuel filter after any TP fuel filter. It nothing goes wrong (channelling, paper disintegrations, etc) the filter will never need changing. If anything does go wrong, then you are safe, if you have the added filter after the TP filter.
"Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO
"Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends.
"Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks.
'79 300D poor body (donor & parts)
"Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004).
"Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO.
Location: Perth W.Australia | Registered: 10 August 2001Edit or Delete MessageReport This Post
Closed Topic Closed
