Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    A loop is a loop is a loop - ahhhhh 84' FORD 6.9l IDI - to loop or not to loop...
My PSD is looped and I'm very happy with it.
Wondering if anyone here has converted an old ford IDI? I'm redoing some WVO fuel lines on my venerable IDI and I'm reading elsewhere that the Standyne injection pumps on IDI's like their return lines to be atmospheric pressure in order to operate properly. I've run it for thousands of miles unlooped but would really like the extra heat looping can provide.
A looped return after the lift pump would supply back pressure and a looped return before the lift pump would supply vacuum. I don't care to destroy the IP via backpressure or vacuum...
I'm wondering if I should just do a return to tank and forget about looping?
Anyone?
2001 Ford Excursion 7.3l PSD
1984 Ford F-250 6.9l IDI
Over 18,000 miles on WVO.
If you loop to before any filter in the line coming from the tank, there is no vacuum there unless you have a pickup screen thats clogged. Put the filter after the lift pump is best, and you can loop before the lift pump where there is no vacuum.
second to sunwizard. if you gonna loop, loop to the inlet before any "restriction" then it will be pretty close to atmospheric
96 6.5td with homebuilt veg conversion
centrifuge setup
about 20.000 kms on oil.
Location: Edmonton Alberta | Registered: 30 May 2008Reply With QuoteEdit or Delete MessageReport This Post
My pump and filter are on the frame rail behind the cab, under the bed of the truck. Getting my loop to go all the way back there would make said loop about 8 feet long Wink
Thinking of looping into the supply line in the engine bay with a T (after the loop valve). Or maybe just putting a Veg Therm Mega into the 8 foot long loop might be OK Smile
Thats still shorter and better than a return to tank since the loop gets more heat.
Sounds bad since that would put the return under pressure?
Shouldn't be needed, simply insulate the whole bundle of heated lines together.
What about air bubles ?, i've read somewhere on the site that if you have a looped return air will accumulate until engine doesnt... ? or there is something else that i didnt understood ?
Registered: 25 July 2009Reply With QuoteEdit or Delete MessageReport This Post
Air bubbles would work themselves out in a filter.
Originally posted by mankypro: Air bubbles would work themselves out in a filter.
hmmmmmmmmmmmmm? then what is the purpose of fancy air filtration units like air dogs or fass?
i have seen what i think are fuel driers on VWs and Intertrashionals they looked as if they sported a cintered bronze filling, minimal fuel volume therefore very suitable, but how effective are they
does any one know?
i have a 6.9 as well as a 7.3 IDI, both will be looped, the 6.9 is in a much more efficient vehicle
and therefore i am planning on doing slightly different setups. do you have a scematic if not could you scribble one up? also do you know of any other ones. i am wanting to weigh out all options...
what percentage of WMO are you running on your PSD?
80's NA VWs & NA and turbo Benzes, '91 E350 7.3 IDI NA
various bicycles with trailers and gearing low enough to ride up a cliff ;-)
Location: Pacific Southwest, USA | Registered: 28 April 2006Reply With QuoteEdit or Delete MessageReport This Post
You mean that in a tank > pump > filter configuration to T the return between the pump and the filter?
No I said "loop before the lift pump where there is no vacuum."
My filters are 9.7" long trust me there is no air issue...
None, the IDI was on 100% WMO for a long time, until I secured enough sources of veggie to abandon it. I still have 110 gallons of ATF/WMO filtered in drums which I will be burning this winter after I finish reconverting the IDI...I will be running 100%
I appreciate the advice, but "before" is relative - and so I asked specifically what you meant - and now I know - thanks! I push through my filter with the Walbro, which is not that common for WVO setups from what I understand. Any advice on that front?
to eliminate air, go a partial loop or ahave a valve to make youre return go to the tank to push the air out after a filter change, i am a fan of a partial loop myself, push the air out, keep some heat in
centrifuge setup
I'm using a third 3 way valve for a controlled loop so simply switching to purge - which will run route diesel through the WVO return to tank line. This will not eliminate air from the loop, but will eliminate any air in the IP and injectors.
but how do people that have looped retrun systems manage to get the air out of their line ?, if it's not the filter ? !
I've never had any air issues on either my IDI or my PSD...
so it would be the filter taht is doing the job on your sytem? what kind of filter do you have ?! thx
On my 87 6.9 I have looped my return to before the stock lift pump, on the advice of Craig Reece at www.plantdrive.com. I haven't had any air or IP issues for the last 40,000 miles on svo.
I don't know how many miles are on the IP except it had been replaced at the time I bought it with 150,000 miles. They often only last 100,000 miles even on diesel alone.
Mike
Registered: 08 August 2006Reply With QuoteEdit or Delete MessageReport This Post
on the IH 6.9L and 7.3L IDIs, does anyone know what percentage of the fuel going into the injectors is burned and how much is shed to the return lines?
The initial startup with all new lines can be a beeyatch - battling air and such, but after a few runs things stabilize themselves nicely. I'm seeing 180F pre-IP temps in very short periods.
I ended up looping to the pump inlet and put the vegtherm in the loop. Helps on cold mornings to get the WVO pump going.
