Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    How do you make a vacuum pump from an air conditioner?
Closed Topic Closed
I've got my sucker all ready to go, (thanks Dana)I just need a vacuum pump. I tried taking an air conditioner apart but I tossed it out when oil came out of the compressor. I can get another A/C unit, I just want to know what I have to do with it.
I had the other compressor out of the unit with no problems. It had 3 wires, I don't see a problem hooking up a plug to it. It also had two copper pipes coming out of it. When I tipped the first one I had, oil came out of one of the pipes.
So I guess I have to keep it upright? If the oil is just loose in it, won't it pour out when turned on?
Advice appreciated
Peter
1983 Mitsubishi Mighty Max with a modified Greasecar conversion.
Location: Stouffville, Ontario | Registered: 08 September 2005Edit or Delete MessageReport This Post
One of the pipe is suction ..the other "blows", and most of the oil is just going to get pushed out anyway so you may as well let it drain. To make the pump last and last add a few drops of light machine oil every now and than.
Dana
दान
danalinscott@yahoo.com
Location: Central MN..Brrrrrr! | Registered: 06 November 2001Edit or Delete MessageReport This Post
Well, after some searching, I found this
http://www.dream-models.com/eco/vacuumpump.html
I seems to answer all my questions!
take a look
Peter
Thanks for the reply Dana
That seems strange that the oil blows out. You would think the compressor needs most of it, not just an occaisonal lube?
Peter
If you are considering about using the airconditioner pump on your reactor be careful. I looked at one of these. Luckily it was being reconditioned and had been cut open. The model that I saw draws the vacuum directly onto the electric motor hence exlosion risk. I opted for a vehicle break system vacuum pump and separate motor to keep things that spark away from potentially explosive fumes.
Location: Tamatave, Madagascar | Registered: 25 May 2006Edit or Delete MessageReport This Post
I was wondering how safe they were.
i am using one to bubble wash the bio. And was wondering how safe it would be to use it a vac the methanol out of the reactor for recovery purposes - and then promptly crossed it off the list as i didnt know how they were made internally.
steve
Registered: 30 April 2006Edit or Delete MessageReport This Post
Some of these have capacitor controlled starting circut . Can some someone explain how to wire up the capacitor start type - Thanks
1994 F250 IDI 7.3 NA E4OD
Location: GA | Registered: 08 November 2004Edit or Delete MessageReport This Post
These motors are not likely to cause a spark, because they do not have contacts in them which arc in normal usage. So, even if you are pulling a vacuum to distill methanol from your byproduct, it should not cause any explosion:
1. you are drawing a vacuum, most of the air has been exhausted before you start to evaporate the methanol.
2. Your source vessel should be airtight, otherwise you will not draw a vacuum and you will not get to evaporate much methanol.
In the unlikely event that you have a short circuit in the motor causing a hot spot, and at that time you have an explosive blend of methanol and air in the compressor, you will have an explosion, but the energy of that explosion is likely to be contained by the motor vacuum chamber, because the amount of air and methanol in the pump is small at low pressures.
"Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO
"Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends.
"Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks.
'79 300D poor body (donor & parts)
"Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004).
"Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO.
Location: Perth W.Australia | Registered: 10 August 2001Edit or Delete MessageReport This Post
I've made a few vacuum pumps over the years from A/C units and I usually take the whole control section if it has capacitor start and attach it to a base that the compressor is hooked to. Like a board or something. Then it is already wired and has a cord.
Location: Cincinnatus, NY | Registered: 12 August 2005Edit or Delete MessageReport This Post
Closed Topic Closed
