Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Frequently Used Abbreviations (FUAs)|
This thread should be taken a step further and put into a glossary on the front page where you see the list of forums. It actually took me a quite a while to guess:
HOH - Hose On Hose HIH - Hose In Hose WOT - Wide Open Throttle Could not find the defs by searching. Speaking of KOH, I think it should be one level up from the 'General SVO Discussion' forum, at the main menu. -Steve Pretty much everything I work on ends up being a total PITA. ********************** '85 6.9L Ford 4x4 t19 |
IJP = Injection Pump
FF = Fuel Filter ELP = Electric Lift Pump MLP = Mechanical Lift Pump PSDFS = Power Service Diesel Fuel Supplement PSDK = Power Service Diesel Kleen Good Vegging and God Bless!! 24,000 veggie/blend miles and counting! Kugel 1991 Ford F350 7.3LNA Diesel ZF5/5-speed tranny: Currently running unheated 75/25 WVO/RUG Blend [WVO - 5 micron prefiltered and regular unleaded gasoline mix] + Power Service Diesel Kleen 6-point Cetane Booster; removed mechanical lift pump, added single electric fuel "push" pump (NAPA #6101049), back near tanks; Fram #G15 (10) micron inline filter at main Fuel Filter inlet; looped IJP return line Tees back into Fuel Filter inlet; Injector return lines still go to stock selector valve and tanks; Fuel Filter Air Bleed tees back into Injector return line. So far, she's running GREAT!! |
No one's listed the obvious:
BD= biodiesel EtOH=ethanol MeOH=metanol. May seem silly to those of us who've been here awhile, but might help a newbie. Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
IP = Injection Pump (Some use IJP)
Metho = Denatured Ethanol (usually 95% pure) IPA = Isopropyl Alcohol MP = Melting Point (eg High MP oils are solid at low temperatures) Abd a couple of non fuel-specific ones HTH = Hoping to Help. IIRC = If I Recall Correctly YMMV = Your Mileage May Vary. "Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO "Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends. "Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks. '79 300D poor body (donor & parts) "Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004). "Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO. |
I guess we might as well add generic internet abbreviations that are regularly used here:
IMO = In My Opinion IMHO = In My Humble Opinion PITA = Pain In the Ass RPITA = Royal Pain In the Ass FWIW = For What It's Worth rOLf 2 yrs and 100k mi on WVO - '93 VW EuroVan 2-tank w/ tank heat/HOH/10-micron heated Fleetguard, FPHE |
member 2008 Sponsor |
How about if I stick a link in the "10 steps" to this discussion? It5 is getting a LOT of hits by folks I assume are newbies. Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, co-generation(power/heat)projects, and Conversion Webinars, |
BTW, how do you link stuff? I've needed to dot hat a couple times and can't figure it out
assume it has something to do with the URL button up top, but can't get further than that... (I'm failing this IQ test) rOLf 2 yrs and 100k mi on WVO - '93 VW EuroVan 2-tank w/ tank heat/HOH/10-micron heated Fleetguard, FPHE |
First go to the site you want to link to, click on the site address and use Edit/Copy or Shift/delete. Then go to the thread you want to link from, click Reply, click URL, then Shift/Insert in the URL box, give it a name in the title box, then click OK.
This is similar to the glossary already listed under biodiesel .
Should we have Shaun consider tweaking it to be an inclusive glossary ? David Norwood 2001 F350 DI on blend . Only one fuel tank . Up to 85 % wvo . HOH for fuel line heat. Add-on Amber Goldenrod 10 micron before OEM filter . dttk44@msn.com |
I figured that much out myself but how do you underline text... oh wait here aha the text is the title, got it thanks rOLf 2 yrs and 100k mi on WVO - '93 VW EuroVan 2-tank w/ tank heat/HOH/10-micron heated Fleetguard, FPHE |
TLA = Three Letter Acronym
2000 Excursion 7.3L Running VO |
UCO- Used cooking oil in some circles. Used Crankcase Oil in other circles
H20- water (gawd I hope that is obvious) #m- as in 5m, 2m, 10m- often used to show the relative minimum micron size a filter blocks. If I'm not mistaken this size is only AFTER the filter is seasoned some. There is a scientific abbreviation for micron that some have used but it escapes me at the moment. B#- as in B5, B10, B20, B100- represents the amount of biodiesel blended with diesel fuel. Sold at fuel stations. LP- Liquid Propane LPG- Liquied Propane gase (same as above) NG- Natural Gas (or abbreviation for an oriental doctor with the last name pronounced as Win but spelled Ngyn or something like that WVO life pending still grrrr Coach George ---------------------------------------- Originally Posted by anvil of Pirate4x4.com your very informative reply has been noted. I think this is the same type of logic you used to draw your conclusion. Place banana in your ear. Observe that there is no alligators around. Conclude bananas placed in ears keep aligators away. |
George, In West Oz, the term LPG refers to Liquified Petroleum Gas LNG = Liquid Natural Gas (Higher Methane content than LPG) |
as a newbie i have two thoughts.
dont over do it. abbreviations that are for this site are fine. such as, WVO and SVO. but once you get into that AOL and teenager sending text messages junk, it gets annoying. "you are " shouldnt be " u r". and, a better definition would help in some cases too, such as, WVO = Waste Vegetable Oil UCO = Used Cooking Oil what is the difference? and, OCH = Oil Can Harry i cant even guess what that means. it is a great idea though, hope i am being helpfull and not sounding too critical. |
Yeah, WTF is that? jake ---------------------------- '99 Benz e300d (SVO conversion underway) '87 Samurai LWB - parts hauler & mule (ACME VW diesel kit, HoH, Pollak) ***Garage full of VW 1.6 + 1.9 bits... for sale!*** |
Funny, I also refer to it is SVO/ straight vegetable oil. It seems to be easier to explain to people who confuse it with biodiesel or blends. Straight vegetable oil can either be used cooking oil or brand new stuff from the grocery store. jake ---------------------------- '99 Benz e300d (SVO conversion underway) '87 Samurai LWB - parts hauler & mule (ACME VW diesel kit, HoH, Pollak) ***Garage full of VW 1.6 + 1.9 bits... for sale!*** |
OCH is actually a need to know thing cause newbies will run across threads that give reference Mr. OCH. His information is pretty interesting. Though I admit reading about his contributions is getting a little out of the relm of NEWBIE info.
Straight Veg. Oil (SVO) is these days more used to describe NEW never used for cooking Veg. oil. For example Elsbett one tank kits expect you to stick with SVO fuel and not use WVO. This is why Elsbett is more popular in Europe where SVO is at times cheaper than diesel. WVO----waist cooking oil- been cooked with stuff UCO----- an attempt was made by some to get away from the term WASTE oil (WVO) cause it conjured up EPA problems with authorities where the term Used Cooking Oil did not (UCO). So folk, including me started using UCO in my messages on this board. Newbies need to know this when reading old material. Unfortunately another whole faction of alternative fuel people (those who heat homes and shops with waste oil) were using UCO as an abbreviation for Used Crankcase Oil. These two different uses of UCO created problems so the UCO term for veg. oil faded out and we went back to using the term WVO. Confuesed yet? WVO life pending still grrrr Coach George ---------------------------------------- Originally Posted by anvil of Pirate4x4.com your very informative reply has been noted. I think this is the same type of logic you used to draw your conclusion. Place banana in your ear. Observe that there is no alligators around. Conclude bananas placed in ears keep aligators away. |
A need to know thing? Are there security issues here?
