Yes its a good one for VO. Get a vegistroke kit they are the best for it:
http://www.dinofuelalternative.../products.php?cat=84 Problems you might get are from home made conversions if you don't know the tricks to the powerstroke's unique, computer controlled hydraulic electronic unit injector (HEUI) fuel system. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
A fine conversion candidate.
However..since the injectors are very expensive to replace you may want to make certain that they are in good condition before you buy the truck. Also..for the same reason you will want to be very certain that any wvo fuel you use has a water level of under 500ppm (I prefer to shoot for 300ppm). Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
