Sponsors    Home    Forums  Hop To Forum Categories  Single Tank Systems    Davco 382 filter in SVO application
EL
Any advise as to adapt the DAVCO 382
to use in a SVO application
What is the function of the check valve
Thank you
DAVCO 382
Registered: 11 February 2008Reply With QuoteEdit or Delete MessageReport This Post
I haven't used a DAVCO but my guess is that the check valve is to prevent fuel from draining back into the fuel tank leaving you with an empty fuel filter.
1-tank Elsbett VW TDI , 115,000 SVO miles.
Location: Ct,USA | Registered: 19 November 2001Reply With QuoteEdit or Delete MessageReport This Post
