Sponsors    Home    Forums  Hop To Forum Categories  Single Tank Systems    mixin in the tank in a 94 citroen zx 1.9d
i got some waste oil from a resturant..then filtered it straight away through a cotton t shirt folded over twice.. poured it straight in to the tank mixed at about 60wvo 40 derv with no other mods can i expect any problems the temp out side is 0 at night and 1 0r 2 degrees in the day
Location: se england | Registered: 05 November 2008Reply With QuoteEdit or Delete MessageReport This Post
You can certainly expect problems. WVO needs to be filtered and de-watered before use. A t-shirt is not a filter, nor does it remove water. Blending must be done throughly before the fuel is introduced to the tank.
I strongly urge you to do a lot more reading and ask questions before you attempt the use of oil in your car again. Why did you decide to do this?
1984 Volvo 240
Elsbett 1 tank/glow plugs/injector nozzles/FPHE/fuel filter heater system, block heater, ILH
20%Kero, 80%WVO winter blend
Location: New Jersey | Registered: 09 August 2006Reply With QuoteEdit or Delete MessageReport This Post
As 240 says you want to take a bit more care.
Your engine could be a good candidate for running oil. They come with Bosch (good 4 veg) or CAV (bad 4 veg) injection pumps
There are lots of people with the same engine doing similar at
http://www.vegetableoildiesel.co.uk/forum/index.php
www.obed.org.uk Open Biofuel Engine Development - Collaborative biofuel engine tuning.
Location: UK | Registered: 25 March 2003Reply With QuoteEdit or Delete MessageReport This Post
